HDMI with vga dual monitor setup help!
Sebastian77
Hello, my current monitor is connected to the hdmi from my graphics card to the monitor and works fine, but I have another monitor that accepts vga only how do I set it up to display on the vga one?
Does your GPU have a VGA out?
If not, your going to be looking at an active converter, or replacing the monitor.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
But it has a dvi out... would that work if I bout that cable? I’m using the hdmi on my gpu and I’m trying to use the vga on the motherboard
I saw what you linked me very much appreciated! Would that go in my motherboard then.. it would have to right?
Yeah I think I answered my own question because my gpu only has one hdmi... but just to be safe if I put it in my motherboards hdmi slot will it work with my hdmi already in my gpu’s HDMI slot
