what capacity battery for mini bluetooth amp
Solved by HanZie82,
Well thats a calculation of the voltage and wattage it uses. I checked the description its not really clear on power usage. Just that its 50Watt and can use AC 110-220 V, DC 12-24V.
I would think if this is really what you want, order it then use it on a lab power suply to find out the Amps drawn at certain voltages/volumes So then you can calculate the battery you need.
edit: please correct my math if its wrong, im sleepy.
But 50 Watts at 12Volts is about 4Amps. So 12(for the hours) times 4 amps is the size of the 12V battery you would need. (edit; which means 48AmpHours)
edit2: If you go for a 24V battery the Amps need can be halved.
