Search In
  • More options...
Find results that contain...
Find results in...
sanjay marison
can anyone say me if my builld is worth the money and parts are compatible
You don't need this "big" cooler for that CPU, get a normal air cooler, you will be just fine.
Get a cheap SSD if you can for the OS.
Recommended Posts
Posted · Original PosterOP
https://in.pcpartpicker.com/list/ZMds3b         (-----------  this the link to my pc build . can anyone check that all parts are compatible ? is the build worth the money.
Don't go with an A320 board. Please. B350 boards are the minimum I'd recommend for a Ryzen 7 CPU. Drop the liquid cooler and stick with the stock Wraith Spire. The aftermarket thermal paste is not necessary, the Wraith Spire has a layer pre-applied.
You can also save a lot of money by leaving Windows deactivated or by buying a cheap key from key resellers.
Go with an 8x2 kit of RAM instead of buying each stick individually. RAM from a kit with multiple sticks is more likely to play nice with your system.
Thermaltake's RGB power supplies aren't the best, and 500W is pushing it for what you've got. I'd go with, at minimum, 600W.
With the money gained by dumping the liquid cooler and leaving Windows deactivated, you should be able to grab a cheap 120-240GB SSD as your boot drive. This is WAY THE HELL MORE IMPORTANT than a liquid cooler.
I'm at work, so I can't do a PCPartpicker list right now.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
Posted · Best Answer
CPU:i7 9700k, Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 GPU:MSI RTX 2070 ARMOR 8GB OC, Storage:Samsung SSD 970 EVO NVMe M.2 250GB, SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB, PSU:Corsair CS 650 M Gold, Display(s):Samsung P2470HD, SAMSUNG LS24E390HL, Cooling:Fazn CPU Cooler Aero 120T, Keyboard: Corsair K95 Platinum RGB mx Rapidfire, Mouse:Razer Naga Mouse 2014Headset: Razer Kraken 7.1 Chroma, Sound: Logitech X-540 5.1 Surround Sound Speaker
2 hours ago, sanjay marison said:
 but still my price goes to 90000 can i do something to reduce it under 80000. 73856.98 + 17000(for the motherboard and ssd)
India PCPP is a nightmare with so many missing prices.
Best I could do. Went with a cheaper case (but with RGB still). SSD is half the size, due to my not being able to fit a decent 240GB SSD into the budget, however this SU800 SSD is quite a bit better than the Kingston.
There was no way I could fit the Ryzen 1700 into your 80k INR budget without making huge sacrifices to the rest of the build. So unless you are gonna stream or do work on your PC, the Ryzen 1600 is perfectly fine paired with the RX 580. The stock cooler is a bit less capable, but still should handle the CPU at stock frequencies. You can always upgrade the cooler later.
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  (₹12847.00 @ Amazon India)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  (₹10200.00 @ Amazon India)
Memory: ADATA - XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-3000 Memory  (₹11320.00 @ Amazon India)
Storage: ADATA - Ultimate SU800 128 GB 2.5" Solid State Drive  (₹2499.00 @ Amazon India)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (₹3230.00 @ Amazon India)
Video Card: MSI - Radeon RX 580 8 GB ARMOR OC Video Card  (₹24499.98 @ Amazon India)
Case: Corsair - SPEC-DELTA RGB ATX Mid Tower Case  (₹5888.00 @ Amazon India)
Power Supply: Corsair - TXM Gold 650 W 80+ Gold Certified Semi-Modular ATX Power Supply  (₹8999.00 @ Amazon India)
Total: ₹79482.98
Generated by PCPartPicker 2019-03-23 15:17 IST+0530
I suppose you could go that route. The RX 570 is only about 10-15% slower than the 580.
Might still put you over budget a bit, idk.
Buy VPN
