Using two PC and 1 pair keyboard+mouse with 1 monitor?
I am using one pc and one laptop on my desk (and 2 monitors in total) and tried to find a solution for having only one keyboard-mouse set.
Best solution in my opinion: buy a keyboard and a mouse that can connect to multiple devices and switch devices on the fly. I would go with logitech products (logitech g613 for keyboard and logitech mx master 2s for mouse).
In the end, mainly because of budget limitations, I went with only buying the logitech g613 keyboard just because I needed an upgrade on my keyboard anyway. For now I am using synergy. I have some bugs when using multiple monitors and specifically when one monitor is being used from both pc and laptop with a hdmi switch. I have some random disconnects that are a really bummer especially when you are actually working and doing something important. I am planning on buying the logitech mx master 2s in the future.
I do NOT suggest you to rely solely on synergy. I don't know if there is a problem with either my pc or laptop (I doubt it cause they are really good machines both of them) or the fact that the pc is running on windows and the laptop on linux (I guess there shouldn't be any problem with that though), but the random and quite frequent disconnects on the synergy are really really annoying!! Even though I didn't have the chance to try it myself yet, I would recommend you to just buy peripherals that can work on multiple devices and switch on the fly. In the g613 keyboard there is none to very little delay (I can't realize any delay to be honest but I guess there is a small one) while switching devices and it's done with simply pressing a dedicated key on the keyboard. So I guess the same goes for their mouse.
