144hz monitor (VG248QE) using hdmi 2.1 with gtx 1060 gpu (PH315-51-78NP) and wont go above 60hz
Go to solution Solved by Glenwing,
8 minutes ago, theviewr1568 said:
do you know if i get an hdmi displayport converter so i could use my hdmi but there would be a dongle do it wold work over hdmi to my computer cause it only has a hdmi
would that work?
You can get up to 1080p 120 Hz though an HDMI to DisplayPort converter, which is about $30.
If you just bought the monitor I would recommend returning it and getting one that supports 144 Hz over HDMI though.
Hello i recently bought myself a new gaming computer PH315-51-78NP and 144hz monitor later on VG248QE and i read that the monitor only had  a hdmi 1.4 so i was ok with 120hz but when i plugged them in  and updated my drivers for my gpu and monitor i could only get 60hz will it hurt the monitor if i use a custom res to force the 120hz or is there something im doing wrong
Did you check the settings on the monitor?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
yes i did i just checked again for like the 144th time
2 hours ago, Glenwing said:
VG248QE is limited to 60 Hz over HDMI. You must use DisplayPort or Dual-Link DVI.
would that work?
You should buy a DisplayPort cable.  They're a few bucks on Amazon, no biggie.
"And I'll be damned if I let myself trip from a lesser man's ledge"
would that work?
