I'm planning on overclocking my GPU and I need help.
Solved by ShadowChaser,
If I had to warrant a guess your system currently draws about 300-350W under load. You could max out the power slider and be fine, but I'd check your power consumption just in case. My personal rule of thumb is to take the tdp and add 20% to it for the average user for a good slightly overestimated number for safety.
RX580: 185W -> 240W
R5 2600: 65W -> 80W
Plus your other components and peripherals ~ 100W
Still under your 550W limit, though efficiency of your system might suffer a little
