What 120mm fans would you recomend for low noise & low cost
Solved by Necrocomputing,
On 3/19/2019 at 12:04 AM, WoodenMarker said:Your temps seem fine.
Arctic P12 PWM's should perform pretty well although I'm not sure how quiet they are. You might as well see how they perform since you already ordered them.
The fans have arrived and I've installed them. I am pleased to say that I now sit quietly and enjoy the new found silence emanating from my PC despite literally having twice as many fans installed. Great purchase; Thx to everyone for the recommendations.
