Search In
  • More options...
Find results that contain...
Find results in...
vWxck
GTAV 16-27FPS Lock Please help
Recommended Posts
Posted · Original PosterOP
Hi guys,
I used to play gta all the time but I had woken up one day to find that my game was playing at 16 to 27 FPS, when honestly i know my pc can do some much better (see specs below)
CPU: Ryzen 7 1700
MB: MSI x370 gaming pro carbon
GPU: Gigabyte 1070 ti 8GB
RAM: Corsair vengeance pro 16GB 3000Mhz
PSU: Silverstone E-T650B 650W
Storage: SSHD 2TB
Overheating has never been a problem and isn't so either right now, I've tried reinstalling drivers & reinstalling the game itself. and it comes to no avail even changing the graphic settings do absolutely nothing. The only thing that changes it is the resolution which i can only get 60FPS when playing in 800x600... Gta is only using 40-45% of ram, usually 11% of my cpu & 10-40% of my gpu. As im still fairly new to computes this is very annoying for me as im still trying to learn...i've tried looking on youtube and other places for an answer but and can honestly find solution. forgot to mention that this is the only game it happens to,
- Thank you
1 Check in CPU-z to see if your conponents isn't weak ones with label of more porefull ones
2 try removing the overclock of the ram, AMD is a pain when it comes to RAM, also turn OFF the XMP it doesn't work properly if it even works
18 minutes ago, vWxck said:
RAM: Corsair vengeance pro 16GB 3000Mhz ( OC to 3600 I believe )
Try dropping it to 3000Mhz, and make sure the DRAM voltage is set to 1.35v. This may solve your problem.
I had a ton of issues with OCing my Corsair Vengeance LPX, even going so far as them causing me to be unable to boot or unable to run beyond 2133Mhz.
PCMR
Primary PC: Lazarus | Build: https://pcpartpicker.com/list/tv7hLJ | Build Log: https://linustechtips.com/main/topic/1000427-lazarus/
Case: Fractal Design Define R6 | PSU: Seasonic Focus Platinum 750W | Mobo: Asus ROG STRIX B350-F | Front Panel: Asus DVD/RW Drive
CPU: Ryzen 5 2600x @ Stock Speeds | 32 GB DDR4 RAM (4x8) Corsair Vengeance 3000MHz | CPU Cooler: Noctua NH-D15 SE-AM4
Storage: 1TB 7200rpm Toshiba 3.5" HDD, 2TB 5400rpm Seagate Firecuda SSHD, 500GB Samsung 970 EVO, 500GB Samsung 860 EVO, 4TB Toshiba X300 7200rpm HDD
Fans: Corsair 120mm SF x 3, Fractal Design 140mm Dynamic X2 x 3 | Peripherals: Asus Strix Flare, Corsair Scimitar Pro | GPU: RTX 2080 STRIX
Expansion Cards: Asus Hyper M.2 x16 Card, Asus Xonar DGX | USB devices: Asus AC66 USB 3.0 AC wifi adapter, Blue Snowball, NZXT Hue+
Displays:  23" 1080p 60Hz, Asus PB258Q 27" 1440p 60Hz | OS: Windows 10 Home x64
Secondary PC: Dell Inspiron 15 5000 Gaming
CPU: Intel Core i5-7300 HQ | RAM: 16 GB DDR4 RAM | GPU: GTX 1050 4 GB | Storage: 1TB 5400rpm Western Digital HDD, 500GB 960 EVO
Tertiary PC: *insert name here*/HTPC | Build: https://pcpartpicker.com/list/8W4cLJ | Build Log: https://linustechtips.com/main/topic/1030228-htpcconsole-build/
Case: Silverstone Grandia GD09 | PSU: Seasonic Focus Plus Gold 650W | Mobo: Asus Q87m-E/CSM | Front Panel: DVD/RW Drive
CPU: Intel Core i5-4670k | RAM: 32GB DDR3 (4x8) Kingston HyperX | CPU Cooler: Cryorig C7
Fans: Arctic F8 PWM x2, Arctic F12 PWM x 2 | Peripherals: Generic USB Mouse, Dell PS/2 keyboard | Display: HP 2310m 23" 1080p
Expansion Cards: Asus PCE-AC55 PCIe AC wifi/bluetooth adapter, (may, add Asus Xonar DG)
Storage: 1TB 7200rpm Western Digital 3.5" HDD, 1TB Western Digital 2.5" SSD
GPU: Asus GTX 960 Turbo 4GB| OS: Windows 10 Home x64
Mobile Devices
Asus Zenfone 4 Max | Battery: 5400 mAh | Approx Battery Life: 3 Days | Storage: 32 GB Internal Memory, 32 GB mSD Card
RAM: 3 GB RAM | APU: Qualcomm Snapdragon 435 @ 1.4 GHZ | Display: 5.5" 720p | OS: Android 8.1
Asus ZenPad S3 10 | Battery: 4000 mAh | Approx Battery Life: 2 Days | Storage: 64 GB Internal Memory, 32 GB mSD Card
RAM: 4 GB RAM | CPU: MTK MT8176 | GPU: IMG GX6250 | Display: 9.7" 2k | OS: Android 7.1
Consoles
Nintendo Switch | 128 GB Samsung micro SD
PS4 Slim | Stock 1TB 5400rpm HDD
Networking
Cable Modem | Asus CM-16
Wireless Router | Asus RT-AC66U_B1
They Weren't even oc'ed my bad... and XMP Isnt on either. Bursthearts is that the name of the program? 'CPU-z'. They problem however occurs on gta only. All my other games run perfectly. And Gta used to run perfectly so i'd assume that they are actual parts.
So you've been running at 2133Mhz the whole time, rip.
https://www.cpuid.com/softwares/cpu-z.html
PCMR
Mobile Devices
Consoles
Networking
no my speed is 3000mhz, and what is this CPU-z suppose to be telling me?
idk exactly why he wanted you to get it.
Supposedly he thinks you have a "fake" part. idk
You could try updating and/or reinstalling Windows. And when you reinstalled drivers, did you use DDU?
PCMR
Mobile Devices
Consoles
Networking
DDU??
DDU??
"Display Driver Uninstaller"
you run it in Windows safe mode, it nukes every remnant of the driver. Then you boot into normal Windows and clean install the driver.
Make sure you disable the Windows automatic driver updates btw.
PCMR
Mobile Devices
Consoles
Networking
Posted (edited) · Original PosterOP
Alright, but remember that it only happens to gta, so would even be worth it?? bc like i said all my other games play absolutely perfect. also after disabling automatic updates where do i go to check for updates?
Edited by vWxck
You may as well try, it shouldn't hurt anything. If this doesn't help, there's not much you can do short of trying to reinstall Windows
PCMR
Mobile Devices
Consoles
Networking
Literally just curious bc im still trynna lean about this stuff. what would reinstalling windows do?
Give you a clean slate with no conflicting drivers or software to potentially cause issues.
PCMR
Mobile Devices
Consoles
Networking
True, true... Also with the ddu where do i go to initiate that? already disabled the other thing.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Scroll down to "Download Locations"
PCMR
Mobile Devices
Consoles
Networking
2 minutes ago, vWxck said:
which one?? lol im in australia
Try one, the only difference should be the server location
PCMR
Mobile Devices
Consoles
Networking
so ive extracted it down to display driver uninstaller and settings. do i just select  display driver uninstaller
Eastman?
