need to turn a 6pin into an 8pin
Munhe
So i have a PSU 600w MS industrial, it has only one 8pin connector(4+4) and one 6 pin, but my MSI gtx 1060 6gb needs an 8pin connector, so what would my best option be? To get a 6pin to 8pin connector or some other way? All help is much appreciated,thank you in advance,btw i am using my 8pin for the CPU(ryzen 5 2600),i know there are 6pins to 8pins conectors i also know there are 12v molex to 8pins(whatever that is)
Get a new PSU mate or does your PSU have any other empty slots available?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
this must be a oem psu?although its never recommended to use adapters, but adaptor do work.
there used to be some 6 pin to 6+2pin adapter comes in the box of gpu(eg my sapphire6850 and a gtx1660ti I recently saw in unboxing ), but never seen 2x 4pin molex to 6+2pin in free.
i used a 350w cheap psu 2xmolex to a 6pin and it worked.
but the psu was a great issue in my case lol
my PSU isnt a very fancy one ,630w MS industrial, it has (this is of the box)
1.20+4 pin
2.4+4 pin 12v
3.molex x2(480mm)
4.Sata x3(480mm)
5.FDDx1
6.6pin x1 connector
7.fan12cm
8.1,2 power cord
So i used the 4+4 pin for the CPU (ryzen 5 2600), and i realized i dont have another 8pin for my MSI gtx 1060 which requires one 8pin connector, based on that what is my best choice of action? thank you all for help btw,i just called the store they have 6pin to 8pin
Adapters will work fine. I recommend this one.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
The EPS 8-pin (which you call 4+4, CPU power) is not the same as a GPU 8-pin.
You can use a 2 molex to 1 pci-e 8-pin power, but that is not recommended.
Get a better PSU. MS Industrial PSU-s are MSAN-s Chinese-made low-quality low-budget PSU-s.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Change the PSU. Who recommended you to use the shit-tier MSAN power supply with a ryzen and a mid-range GPU?!
an idiot( me :) ) first time building my own PC, and i guess i am just not well informed on PSUs, so which one PSU would you reccomend,for now i will stick to adapters until the next paycheck
so i need an 8pin that has 2 molex adapters on the other side? did i understand that well?
and the 8pin for CPU is ok??i dont need to fix that one
Throw that PSU into a fire, before it starts one.
Get a good PSU.
Where are you from?
Can you provide a link to some stores?
2 minutes ago, Munhe said:
@Uptivuptizwait you mean 8pin to molex? i need one 8 pin for GPU
Whoops. Sorry about that. Wasa little too fast for even myself. :D  Here's a SATA to 8 pin PCIe power.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Just now, Comic_Sans_MS said:
No. Just no. SATA connectors will melt when you have 75W going through them.
The OP's PSU is a piece of shit. They need a new PSU.
Savage, but ok.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Consult the PSU teir list in the powe supply section of the forums or just ask in a thread.
so i shouldnt use those sata adapters?? damn i am confused right now
https://gigatron.rs
i am from Serbia there are good PSUs here, but for now i dont have money for one, might look up a used one? is that a good idea or?
Yes, your best solution would be to replace PSU with something better.
What would be your budget? Location?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
Location Serbia
https://gigatron.rs (this is the store website) one of the more popular ones,
the budget is not an issue i guess, i got money, but i dont want to go like 150$ for a PSU, so should i be better of getting a modular PSU? is that the best option?
1 hour ago, Munhe said:
Location Serbia
So i had a look at that website - thank god for google translate.
https://www.gigatron.rs/napajanja/antec_napajanje_earthwatts_gold_pro_650w__ea650gpro-124406
this would be your best bet if it has to be from that website at the lowest price possible for a decent PSU. It also has plenty headroom for future upgrades to your system.
120$ for a PSU :(  god damn, thats almost the same i payed for a CPU. buy yeah i get your point in getting the one with space to expand. what else makes this one good? except a lot of PCIEs ? is a used PSU good?
1.20+4 pin
2.4+4 pin 12v
3.molex x2(480mm)
4.Sata x3(480mm)
5.FDDx1
6.6pin x1 connector
7.fan12cm
8.1,2 power cord
Yes, your PSU is shit.
 I've found it in a shop for under 20€.
So you have to replace it, if you want to have fun with your PC for more than a couple of months, until that piece of electronic waste and pollution destroys everything you have and even maybe kills you.
Yes, its that bad.
So no, get a decent PSU. The amount of connectors screem "I'm shit, pls don't use me"....
Yes and a bar of dynamite as well.
And the dynamite has its use.
The PSU he has can only be used as a paperweight, maybe self defense device.
Except that it has no use. And the Energy and material to make it were totally wasted.
"Hell is full of good meanings, but Heaven is full of good works"
Yes, its that bad.
You're the gordon ramsay of power supply.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
thank you
