Search In
  • More options...
Find results that contain...
Find results in...
jakkuh_t
Making my 1980's Garage Door Smart!
Recommended Posts
Posted · Original PosterOP
After getting IMO ripped off by Chamberlain, I decided to take smart-ifying my garage door into my own hands.
Buy the Garage Door Opener:
On Amazon: https://lmg.gg/8KV9L
Buy the Roost Garage Door Sensor:
On Their Site: https://lmg.gg/8KV9N
widget.png?style=banner2
Gaming Rig3900X, 32GB 3600MHz TridentZ, ROG 2080 Ti, 2*4TB Black, 1TB MP600
NAS: E5-2670v3, 48GB ECC, 76TB of HDD's: 3*4TB + 2*8TB + 4*12TB, 500GB 850 Evo Cache
same with the Wan show
happening way too much since last 3 weeks.
Intel i7 4790K (4.0 GHz) | MSI Z97-GAMING 5 | Corsair Vengeance 8GB DDR3-1866 2x8GB | Asus GeForce GTX 780 Ti DirectCU II OC | Samsung 840 Pro Series 256GB | Corsair RM 850W | Corsair H90 94.0 CFM | Logitech® Wireless Combo MK330 | Cooler Master HAF XM | Dell S2240L 60Hz 21.5 IPS |
PCPartPicker
The cringe factor is what makes this so good and bad at the same time.
Can Anybody Link A Virtual Machine while I go download some RAM?
I have a feeling that soon after a home project this this.. the old garage door openers will fail and then he'll have to install that/those subscription based openers anyway
Do you really trust that Chinese company's security though? I've seen a lot of dives into these cheap WiFi controlled switches where it turns out the API is just an incrementing serial number so anybody can hit your switches with commands.
6 hours ago, Mitty996 said:
Does the door-open / door-close status (Roost module) work when you are not on your local wi-fi (from work for example)?
Yes. Ewelink is a cloud service for those kind of devices. Sonoff devices uses this cloud, too. You got IFTTT, Google Home and Alexa support.
This is why I flashed my sonoff devices with tasmota. But you'll lose the cloud functionality. But you can regain it when you use openHAB or something similar.
This is exactly what I do: I like Sonoff's hardware, but I replace the firmware with Tasmota and control them and query their status over MQTT with OpenHAB, and I can access it all over the Internet as well.
What about nold.io ?
it use Bluetooth to connect
and use cloud and API
Also on iPhone you can open the door when you get in range ( maybe later also on Android ? )
But it is a bit more expensive then 30$
and it is more to share acces then to just open your garage xd
but atleast it can make all kind of stuff “smart”
greets from powerchaos
If you see strange text like this
then you can be sure I use a mobile.
All info provided is to help you. I can not garantee That iT is 100% correct. Apply my solution at OWN risk. Just like overclocking has everything a risk
glad to help you
greets from PowerChaos
I converted my garage door opener as well, but I used there Meross Smart Garage Door Opener, so I can control it via the app, Google assistant, and can use IFTTT or Stringify to add more features.  The smart opener came with the sensor that tells of it is open or closed.
anyone have a good idea/link to some kind of sensor to check if the door is closed?
I can wire up my own switch/sensor, just need some kind of feedback from it foe me to view remotely?
(roller shutter doors at work)
best I can find are temperature sensors 😞
EDIT: I really want wired too, not battery power
Hall-effect sensor.
Is there a more thorough walkthrough for this sort of thing for the less-than-genius of us who are enthusiastic to do this DIY project? Specifically, wiring guides and shopping guides? Like there are *so* many "inching relays" on Amazon, I don't even know what I'm looking at to compare them.
the bit I'm stuck is feeding something back into the network so I can check the status remotly
So, you're just looking for some readymade thing that's plug-and-go? Then I don't have anything to suggest. I'm more a DIY kind of a girl, I'd just use an ESP8266 or ESP32 with a hall-effect sensor feeding to an OpenHAB-server.
I want something in the same way I can find wifi temperature sensor, but wifi "is this switch open or closed sensor"?
I don't know if it's just me or my brain isn't working today 😮
Do they not discuss this with the Roost Smart Garage Door Sensor in the video?
that's just a level sensor, checks the angle the sensor is at, so won't work with my roller shutters and its battery powered
I can wire switches up to open/close if the door is open/closed... but how do I feed that back into my network?
Ah, my bad. Sorry. I suppose you could go with a cheap security camera mounted on the garage door mechanism and pointed towards the door. It might not provide notifications of open or closed, but you could open the feed to look and see. (Added bonus - slightly more security.)
Great video.  and something i've been thinking of doing to my garage door for a while now.
But can you configure this thing to NOT log into the cloud (other than adding firewall rules for that device) ?
I can just VPN to my (tomato) router whenever i need to access my network from afar anyway.
