Search In
  • More options...
Find results that contain...
Find results in...
Second2q2
Will pure rock slim cpu cooler fit ????
Recommended Posts
Posted · Original PosterOP
Hello! I’m new here and was wondering if anyone can help me.
so just yesterday my cpu fan started making a wired noise I took a look at it and cleaned it and it still makes the noise. So I decided to buy a new cpu cooler and I came across pure rock slim and was wondering if it will work with my pc? I don’t know whole a lot about computers so I took some images of my motherboard/cpu
If the Slim Rock has an FM2 (the socket for your motherboard) kit that lets it fit on your motherboard, it'll probably fit.
PSU Tier List
  PCs and other things:
Current PC
CPU: AMD A8-6600k (@4.2Ghz)
GPU: GTX 1070Ti 8gb FTW2 iCX
Motherboard: GA-F2A78M-HD2
RAM: 8gb Patriot DDR3-1600mhz
Storage: Samsung 830 EVO 120gb, WD Blue 1tb 7200RPM
PSU: SeaSonicM12II 620w (I wish I didn't buy this)
 Peripherals: Logitech G305//Corsair K55 RGB
Displays: Asus MG248QR//Dell 1905FP
New PC (getting parts)
CPU: i7-8086k [✓]
Cooling: EVGA CLC 280 RGB [✓]
GPU: EVGA GTX 1070Ti 8gb FTW2 iCX [✓]
Mobo: GIGABYTE Z390 AORUS PRO [✓]
RAM: XPG SPEXTRIX X41 2666mhz (Grey) [✓]
 Storage: T-Force Delta 250gb, WD Blue 1tb 7200RPM [✓]
PSU: 650w+ and ranked well
Case: Fractal Design Meshify C White
Peripherals: Logitech G305//Corsair K55 RGB [✓]
Displays: Asus MG248QR//Dell 1905FP [✓]
Extra: Sky blue front panel, sky blue cable extensions [✓]
Other
Phone: Huawei Mate 10 Lite (China steal my data???)
Dog: Irish Water Spaniel, Lucy, 9 years old (I didn't know what to write)
School Laptop: Acer Chromebook R11 ((less RAM than my phone)
What case are you using? Can you measure how much clearance there is between the cpu and side panel?
Please don't make duplicate threads -- they've been merged.
The Pure Rock Slim is FM2+ compatible and it certainly looks like you have enough room for it. While you're upgrading, consider doing future you a favor and making that AcBel PSU go away.
Sabre - i7-8086K - MSI GTX 1070 Gaming X - AsRock Z370 Fatal1ty Gaming K6 - 16GB Corsair DDR4-3466 RGB - 250GB Western Digital Black M.2 NVMe PCIe 3.0x4 - 1TB Inland Professional SSD - 960GB SanDisk Ultra II - 4TB Seagate Barracuda - Corsair RM650i - Fractal Design Meshify C White TG - Noctua NH-C14S
Senketsu - i7-6700T - Gigabyte GTX 1060 6GB Windforce - Gigabyte GA-B150N Phoenix - 16GB Team Elite DDR4-2400 - 240GB Crucial M500 - Silverstone SF450 - Enermax Steelwing Red - Rosewill RCX-Z300
Hypnotoad - i7-6700 - ASUS Dual GTX 1060 3GB - AsRock Z170AX1/3.1 - 12GB Kingston HyperX Fury DDR4-2133 - 128GB Samsung 850 Pro - 1TB Seagate Barracuda - Corsair CX550M - DIYPC DIY-J21-BK RGB case - Cooler Master Hyper T4 - Aigo RGB fans - RGB strip - Unicorn vomit
The Little Pentium That Could - Pentium G3258 - MSI GTX 1050 Ti LP - ASUS H81M-C - 16GB Patriot Viper DDR3-1600 - 480GB SanDisk Ultra II SSD - Silverstone SF450 - Athenatech A100BB - Arctic Alpine 11 Plus - Spunk
Did you find out if old cooler fan even was the reason for noise?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
