Multi monitor mount
Makato333
I own a "Acer Predator 34-inch Curved UltraWide QHD (3440 x 1440) NVIDIA G-Sync Widescreen Display (X34 bmiphz)" and would like to know if there is a multi monitor mount that supports this? I have not been able to find many details of anyone doing a multi display set up using this monitor. I ideally would like to use this with a few cheap 1080p displays on the left, right, and above this monitor. What I am trying to get at and am wondering is there any multi monitor mount that support this 34inch display and one on each side of it (and possibly above it) and if so could you point me in the direction and give me any advise on challenging that maybe faced and display choices if needed.
I do not know for 3, but i have seen for 2.
Then just get 2 mounts
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
You're much better off just buying a few single arm mounts. Plus it lets you position them where ever you want.
This kind of set up doesn't make sense for a multi arm stand.
Welcome to the forum!
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Thanks a ton! I will search for some single arm mounts instead!
