Questions about positive and negative air pressure within a case.
IMO, air pressure is not solely measured by the case fans, sometimes the GPU (depending on it's exhaust style, ie Blower) and the PSU play some role. RPM and fan-size matter also, not just the number of fans (which I'm sure you know). Passive exhaust plays a role as well, whether or not most of the case is air-tight or has machined holes. Cable-management also can affect air-flow.
I was just reading last night about how depending on passive ventilation/card style you might be recycling warm air into the GPU, which was pretty interesting. Unfortunately I can't find the article with the GPU consideration.
Jay had a video where he used incense smoke to visualize what the air inside his PC was doing depending on how he arranged his fan setup. It really helped to see how big an impact his passive vents had.
