HAMR drive estimated power consumption
Solved by Sakkura,
34 minutes ago, VictorN2990WX said:Whoops, i googled and read it wrong. But does this mean that the new drives will only use 0.0019 watts? (if it is linear), which it probably is not)
Well, it's hard to only heat up just that one tiny spot you need, so it might be quite a bit more - just not a thousand times more. And this is just the extra power use, in addition to the power required for just the regular operation of a hard drive. I think the tentative conclusion is that the power consumption of HAMR drives shouldn't be much higher than normal hard drives.
