  • entry
    1
  • comments
  • views
    820
case for a 360x80mm radiator
LoafMan
i am a beginner and i have to move my computer into a new case as it doesn't all fit properly. my system is water cooled with a 360x80mm radiator and 2 140mm rads for the gpus. what case will all of this fit in. i like the look of the NZXT switch 810 and corsair 760t/780t and i kind of like the enthoo pro but will they fit everything in. i have 2 gtx 970s, 4790k, z97a mobo. the case also needs to fit reservoir, etc and needs to be white, does anyone have a suggestion for any case preferably under $250 australian
0 Comments
