Power Supply
  • entries
    5
  • comments
    13
  • views
    1,141
HELP Power supply
Ethers
Hello,I have a corsair cx 750w power supply and since I bought it every time I hit it lightly my PC restarts .I think it might have fixed its self but I don't wont to try.And when I start playing a game it makes strange high pitch noises. I would like to by a new one so my question is will a 600w super flower PSU be enough for my RIG:
cpu:Intel core I7-3770 ivy bridge 3.4GHZ
gpu:asus strix nvidia gtx 970
MB: asrock h77m LGA 1155
2x4gb RAM 1600
1xHDD western digital blue 1tb 7200
1xHDD seagate 500gb 5400
1xssd kingston 120gb
CPU cooler : thermaltake frio silent 12 (the one fan model)
Thank you for your time :)
6 Comments
Well my AMD power-siphon uses about 525w under full load and I have a TX-650w. So I'm 99% positive a 600-650 watt PSU would be just fine for your rig :)
That sounds like coil whine to me... Go to http://www.coolermaster.outervision.com/ to check about how much power your system will need. Remember that it is nt 100% accurate so you will need to get a bigger wattage PSU then it recommends :)
I have done that it says 344w but I don't think a 400w power
supply will be enough :)
