Stage 1: Showoff and Planning
First off, thanks for taking a look at this, means a lot. :)
Recently, i have acquired Apple's Mac Pro Gen5 case, which i have wanted for ages. My plan is to custom fabricate a new back I/O plate and the motherboard tray, to make it fit an (m)ATX board, and its expansion. I wish to make a mod worthy good enough that i can ask for sponsorship from companies to be able to fit it with hardware as good as the case itself is. ^_^
I got it in this state. Physically its in a great condition apart from the dirt, since it was apparently sitting in a shed for the last couple of years
As you can see, the front is still as classy as it was when it was new, and im planning on keeping it that way.
The insides are extremly roomy, im actually looking forward to working in here, nowhere to cut yourself on.
The back will soon go away, will be replaced by a very similar design, but able to accomodate the ATX form factor
It still had the plastic foil on the (4.5mm thick) side panel :D
If you have any questions, please do ask :)
Hope you have liked what you have seen, and be sure, there will be even more awesome stuff coming soon, so subscribe. ^^
4 Comments
