  • entries
    2
  • comments
  • views
    3,030
A more reliable way for troubleshooting PCs
Try testing the CPU with Prime95 with the Small FFTs option for a hour.
Try testing the RAM with Memtest86 for 3 hours.
Try testing the GPU with GPUPI 3.3.3,Press Calculate then use the following settings:
Quote
(Press cancel if a message about HPET appears)
32B HWbot GPU
choose your GPU in OpenCL GPU devices
Batch size: 20M
Reduction size: 512
Then press OK to start.
Try testing the GPU with MSI Kombustor for a hour.
Tell us if you get any errors while testing.
Prime95 download page:
https://www.mersenne.org/download/
Memtest86 download page:
https://www.memtest86.com/download.htm
GPUPI 3.3.3 download page:
https://www.overclockers.at/news/gpupi-international-support-thread
MSI Kombustor download page:
https://msikombustor.com/#MSI_Kombustor_Download_for_PC
0 Comments
