My friend HP 4540s charger broke need help.
Marij
Hello I just wanna be a good friend and want to buy my friend a new charger does anyone know a good charger for HP 4540s that is reliable and not too expensive. Its rated at 19,5W and 4.26A. Any help would be appreciated!
Delta makes some of the best power adapters out there if you can source one that is of the same voltage and 4.26Amps or greater with the correct connector it will work with the laptop no problem.
Get a original HP charger.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
Getting an original HP replacement charger will be ideal of course, but any good quality multi-laptop Universal charger will work. I'd suggest avoiding no-name or off brands. Acer, Targus, Belkin, etc, all make universal adapters. They are usually auto-sensing for the voltage, and as long as the amperage rating is higher than the draw, it'll only pull what the device needs.
On Amazon.com, you can get official HP adapters for that model of laptop for as cheap as $55 or so.
FYI, are you sure it's 19.5W, and not 19.5V? 19.5W is basically nothing. That equals 4.6V at 4.26A, which is reallllllllllllly low for a laptop. Most Laptops draw closer to 60-90W.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
