NZXT phantom 410 fan help
jvo33
Guys, my friend is having trouble with his fan controller with the phantom 410 case. He runs 12 case fans (don't ask why), but as soon as he turns the fan controller to high, the fans all shut down after 15 seconds. Currently running a 750 watt power supply, and a gtx 570. Do you think the psu is the problem? or something else is wrong?  ANY help would be great. Can't seem to wrap my head around why the fans keep shutting off when running full load.
The simple thing to do is start unplugging them one at a time, set the controller to high and wait if it does it again. My theory is you're drawing too much current for that little fan controller.
Do you even fanboy bro?
HOLY CRAP. didn't even think about that Liltrekkie! Will give it a try and report back. Hopefully its just an easy fix such as this. :D
Let me know how that goes! Glad I can help
