Does running a power supply at 80 to 90 of it.s watts limit when gaming
yory22
Can damage your psu and you pc ? I mean if you have a quality seasonic 650 watt and your system needs 600 watt or little more during gaming can that be bad
as long as you have a quality power supply you can draw as close to 100% as you want.
that said, if you're building new, you should foresee some headroom.
No, it should not damage the PSU, especially if you have the aforementioned Seasonic. If you have a cheap one that can't pump out enough amperage or loses oomph when it's hot then perhaps but with a good PSU, no.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
My PSU can draw 800W fine for extended periods of time - SeaSonic won't fail because you are using them as intended :D
It's fine but the psu won't be running at it's optimal efficiency under that kind of load and temps might be a little higher too.
Not having enough power can definitely bottleneck your performance, if that's what you're asking.
