I need a new battery. Help?
Solved by onVacation,
First of, you probably don't need a battery, but a PSU. Regarding the size: The one mounted in there is an ATX PSU, which is 140mm long and therefore fairly small. I'd stick to this size to be safe, but you could also just open your case and measure by yourself how much space you have for a PSU.
Although you don't need 500W for your current system I'd suggest this PSU: http://pcpartpicker.com/part/evga-power-supply-100b10500kr It's a good bang for the buck and there are no quality PSUs in that low watt range under 400W.
