Galaxy S6 Edge Memory leak? Need help
Ethn
So, I got my S6 Edge about 3-4 weeks ago, I've installed a few apps eg skype, twitter and all that and one or two games, Now without using any applications on my phone at idle it's using 74% of my ram? This shouldn't be happen with the 3gb of ram and the amount I have paid for the phone, I googled it a bit and people are suggesting rooting the phone and editing proprieties but I don't want to be messing my phone up. If I did root it and then if Android released a official fix wouldn't it interfere?
my close friend has the same problem, dont know if its still ongoing for him though
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Ram usage is not a problem on android, the os actually keeps often used files in ram to make things snappier
Disregard females, acquire currency
Same thing happens on my S6 Edge. Really high RAM usage even with just a few apps running. I clear all running apps in the native task manager and it's still around 60% RAM usage. It doesn't feel like it impacts performance though. Hopefully it will be fixed with a software update soon.
"Rawr XD"
I know it doesn't affect it but the fact it's there  just makes me angry hahahah Does anyone know how to make the clock show when the screen is off? I can do it on the edge lighting thing but sometimes when I take my phone out of my pocket there is this clock on it and it is frustrating and I want to know how to do it manualy
