Phanteks Evolv ATX PWM Hub
Ogl
Hi,
I have Phanteks Evolv ATX case which has a built in PWM fan hub and according to the case manual the PWM connects into the CPU header. I also have a Corsair H110i GTX AIO cooler which say the pump should be connected to the fan header as well. So if I plug the PWM fan hub into the CPU header where do I then plug the pump connection from the Corsair H110i GTX.
This my first build so I may be a stupid question but I'm not sure what to do.
Cheers
CPU:  Intel Core i7-4790K 4.4GHz | Motherboard: Asus Maximus VII Formula | GPU: EVGA GTX 980Ti Classified | SSD: Samsung 850 Pro Series 256GB | Cooler: Corsair H110i GTX
Case: Phanteks Enthoo EVOLV ATX     RAM: 16GB Corsair Dominator DDR3 1866MHz | HDD: 2TB Western Digital | PSU: Corsair AX850i
Keyboard: Corsair K70 RGB | Mouse: Corsair M65 RGB | OS: Windows 8.1
Hi,
Cheers
I would plug the pump into the CPU header, for the fan hub as long as you have true PWM header on your motherboard you can connect it to another header.
EDIT: (page 31)
http://www.phanteks.com/assets/manuals/Enthoo%20Luxe%20Manual%20Western.pdf
