NZXT Phantom 820 LED Fans
ChiJumpman
Hello,
I am using an NZXT Phantom 820 Case for my build and I wanted to use LED fans, but I think the LED fans may work in the front of the case. Is this true?
For those who need to see the case itself:
https://www.nzxt.com/product/detail/96-phantom-820-full-tower-caes.html
For People who need to see Linus review the NZXT Phantom 820:
https://www.youtube.com/watch?v=k7hiVxJE42c
Thank you,
ChiJumpman
Should work fine I think
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
Not quite clear what you are asking.
LED fans will work just fine in the 820, but due to the fan mounting location and the shape of the front panel will not be all that visible.
