Help with radeon R9 280 graphics card
hey guys i need help troubleshooting my graphics card.
i have a radeon R9 280 and i have a asus maximus ranger vii mother board and i when i put the graphics card in to the PCIe slot it doesn't output video i have
a acer vga monitor and i am using a vga to hdmi converter the on board graphics work fine but i don't think the motherboard can sense my graphics please help
Go to your Bios and find the graphics section, Your onboard is prob set to primary...without multiview/multimonitors enabled to enable your dedicated gpu yet...
Eeither set Graphics to PCIE/Primary and enable multiview/use onboard for multimonitor, or use onboard as primary and enable multimonitor so the 290 can be enabled alongside it.
Sounds a bit confusing, but when you see the graphics options in the bios it should be straight forward, if not come back and ask..
Provide a bit of detail what the menu looks like and what options it shows. As we cannot see it from here ;P
/Or post your Motherboard Make & Model, we can go look at the manual and find it easier.
