Power buzz/hum/zap, not PSU
Solved by Novistion,
Figured it out. It's my Seagate 3TB
I don't know why it does this but right now it is behaving normally. Even when it makes the sound & resonance it works normally as far as I can tell.
Now that I know it's a HDD, should I be worried? It's 2 years old and has about 650GB free space, defrags on a schedule and isn't on a power saving plan. It's mainly full of movie files, with some music files.
Unplug it for a while and make sure you have a back up of it. One of my WD Black2 did that and I had to get another. Also please mark as solved
