What is wrong with Noctua as case fans?
Thanks for the answers guys.
But I just want to ask this. Even though the NF-F12 is a static pressure-optimised fan, is it still better than a CoolerMaster Silencio airflow fan at the same RPM?
LinusTechTips did a video where they replaced the stock case fans with Noctua static pressure fans and the temps did went down, and they weren't airflow fans. So are pressure-optimised fans better than airflow fans for case cooling (even though airflow fans are designed specifically for case cooling)? (Yes Noctua pressure fans are expensive, but lets just ignore the cost and assume the same RPM)
Again, rpm isn't a good comparison as it really doesn't matter. Performance/noise is the better comparison.
I'm not sure how exactly the Silencio FP120 performs as it's relatively new and there hasn't been many tests of them yet.
http://www.dvtests.com/cooler-master-silencio-fp-120-3pin-and-fp-120-pwm-test-and-review/
More or less my educated guess so do take it with a spork of salt:
From my initial impressions, it seems like the FP120 is more static pressure optimized and more reliant on rpm than the NF-F12. At much lower speeds, the NF-F12 would probably perform better while being quieter and the FP120 should excel where static pressure is needed and very low noise is less of a concern (basically at mid to higher rpm comparisons).
I'd guess it boils down to the FP120 performing better where air needs to be moved around a wall and noise isn't a concern and the NF-F12 performing better when low noise is the objective and air needs to be shoved in the direction the fan is facing.
Also, if noise is not a concern at all, the NF-F12 should perform quite a bit better at full speed but be much louder.
