I need help with this cooling situation.
I have the cooler already, (Noctua NH-L9a) and I'm worried if I try it again it might overheat or something. Also, the Hyper 212 Evo won't fit in my case (Fractal Design Core 1000) without a bulge on the side panel. Thank you for your reply.
So you are saying it should work with my CPU? And will I get lower temps if I use the Noctua cooler I have? Sorry about all the questions, I just need to make sure.
Thanks for the reply.
I already have the cooler, it just didn't work for me last time (second and third paragraph of my post).
There should not be anything wrong with the cooler as it's very high end and didn't you say last time it was a faulty mother board anyway? If so then I would go for it just make sure everything is switched off (at the back of the power supply) when you're messing around inside your case and make sure you are plugging it in the correct place (it should be marked something like ''CPU_FAN'') and preferably look into getting some anti-static wrist straps if you want to be as safe as possible. About performance, Yes if you decide to use the Noctua cooler even with one of there stock type cooler configurations like the NH-L9A you should see a lot cooler temps and a lot less noise too. Might even be able to do some light over clocking if you're in the mood! For a smaller case like yours I would actually recommend one of there 92mm tower coolers which should still fit inside your case (still make sure before you buy one) and provide a lot better cooling than there stock style coolers. Still if you're planning to run stock speeds or slight over clocks then the Noctua you have should do the job just fine Remember to click mark as solved if someone provided the answers you were looking for and feel free to PM me if you have any more questions
