Shorted power supply/ Dead pc? HELP? o.O
It's happened before and nothing else ever got damaged. What would be a good PSU?
A $20 chinese PSU with a supposed 750W rating is like a hand grenade with the pin pulled. You never know when or why its going to blow up or just stop working or fry your components, but its going to happen sooner or later. I recommend just staying away from those things. Good PSUs would be anything from Corsair above 600W, Silverstone ST60F-ESB or the EVGA 600B, for example. All are good PSUs and fairly affordable.
Yeah you're right the amps are way to low
But actually my psu says it has 38a in the 12v and from what I can find the gpu only needs 32a?
Reports differ from 30 amps to 48 amps. I'd stay safe and assume it needs 48. Even if it only needs 32 amps, I'm pretty sure your PSU isn't even getting close to that, no matter what it says on the box. The thing with these cheap PSUs is that they never actually perform anywhere close to what the manufacturers say they will do. Some of them have been known to have fake components made of cardboard and cement inside, just to make them look like there's any performance parts in there.
