Need help choosing LED strips for my PC
Meawa
I am going to get some LED stips soon, the inside of my case looks so dark without them :(
I need help choosing LED strips,
My budget is around $10 will go a little over if nessacary (like $2-3)
i7-5820K | ASUS X99-A | Corsair DDR4 LPX 16 GB | MSI GTX 970 Gaming | Corsair 750D | WD Black 1 TB | MX100 256 GB | EVGA SuperNOVA 750 Watt | ASUS VG248QE | Corsair H105 | K70 MX blues non-RGB | M95 | H1500 | Windows 8.1 64-bit
Yes, Bitfenix LEDs are one of the best LEDs available.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Does anyone know how these LED strips are powered? I only have 4 fan headers on my MOBO, all of them are being used. Does anyone know how these are connected? (like Fan header, mollesk, SATA power, etc.)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811997056&cm_re=bitfenix_led_strip-_-11-997-056-_-Product
In the pictures it looks like there is a mollesk connector in there, but there is also a fan-header looking thingy.
it could be molex, it could be a fan header. IDK
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
The 4 pin connector is just a LED type style 4 pin connector it needs to be adapted to the molex to power the LED strip itself from your PSU.
Definetly not mollesk, as they live in the sea.
Probably molex
Someone really needs to come up with an alternative to Molex.
Dubs are better than subs
Or manufacturers should start using SATA Power for stuff. Correct me if I am wrong but SATA Power and molex both have 12V and 5V
My modded Air 540 build
DarkSide LED's use 3 pin fan connectors those work great especially since when you connect them to fan controller or motherboard headers using voltage control it lets you dim them slightly, not as much as 12V PWM controllers but still fairly good amount.
Yeah, that is not a bad choice either. At least for LED's that is. :)
Hi there! We offer some good LED strips!
Here are our premium LED strips: http://modguru.net/product/led-strip-rgb/
And if you purchase our controller too, you will get an free 4pin molex adapter: http://modguru.net/product/rf-rgb-controller/
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
