Need help choosing LED monitor
bayonet14
http://www.kagoo.com/TVs-Monitors-Projectors/PC-Monitor...
That's my monitor
My friend wants to buy that. If I sell it to him I'll be buying either of these 1080p monitors
PHILIPS 22" 222EL1SB/97 LED MONITOR
http://www.enigma-phil.com.ph/?page=prodinfo&id=50&pid=...
HANNS-G HL227DBB 21.5'' LED MONITOR
HKC 21.5" N2112 LED MONITOR
I know it's worth it to upgrade to 1080p but I don't know if I can trust those brands. Which one should I get?
All 3 appear to be TN monitors. What would be your max budget @bayonet14? I could probably find you some better IPS monitors than those TN panel based ones. ;)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
I've narrowed everyting down to availability, location and price. So I have to choose between those 3. I also want to know if it's worth it to transition to 1080p since the monitor I'm planning to buy is 21.5-22 inches from my current 20inch monitor.(small difference) My specs are i3 4130(gonna get i5 in the future), R7 260X, 8GB RAM
