Hardware malfunction? Need help pinpointing the problem.
Solved by DigitalHermit,
Alright. RAM seems to be fine. At least that's what the memory check resulted in. Also in regard to the second poster, the Hard Drive does not make any hearable noises. But I can listen to it working, even when the notebook is idle, when I get my ear close enough to the area where the drive is. The noise is a continuous spin-like noise, and a frequent tic or scratch noise which, I assume, is being produced by the reading heads right ?
That might be normal operational noise...
Have you checked for fragmentation? I recommend using Defraggler...
Also, please quote the person you're replying to... It's the third button from the left at the bottom of the post...
