First PC build advice and OS help
MajicMan
1. Budget & Location
$1,700 (US dollars)
2. Aim
Photoshop editing, work and gaming.
3. Monitors
Run two monitors.
4. Peripherals
In need of OS. Can anybody tell me about Windows 7 OEM as the retail version has become extremely expensive and I would like to buy this tonight or Halloween. I completely HATE Windows 8/8.1.
5. Why are you upgrading?
My current systems is ancient and can no longer do what is necessary.
I am wondering what to do about a cooling system I am thinking of a fan as liquid CLC
coolers worry me for leaks and I am not sure they give more benefit than some fan coolers>
I will gladly take suggestions for the cooler and any modifications along with whether the OEM version of Win7 can be placed on more than one machine (Please note, I will not be running the same license on multiple systems at the same time, I just want to know if I can move the OS to a different PC in the future if necessary).
My build so far.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($329.98, SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard ($144.99 Amazon)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory ($154.99 Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($109.97 SuperBiiz)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($102.99 Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($363.02 Amazon)
Case: NZXT Phantom (Black) ATX Full Tower Case ($99.99 - $20 mail-in rebate $79.99 Newegg)
Power supply:EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply (109.99 - $20 mail-in rebate NCIX US)
Optical drive:LG BH16NS40 Blu-Ray/DVD/CD Writer ($89.90 B&H)
Total: $1475.82
Thanks for the help>
Windows 8 will give you better performance though... And once you install a start menu and disable charms, you won't notice a huge difference.
Bummer. Time to upgrade.
I've yet to hear of an AiO closed loop liquid cooler leaking. Noctua's NHD14/15 are great alternatives if you prefer air.
Yes, technically, you can move an OEM to another machine if you have the install ISO and key. However, it's not legal. It's just doable. Usually the OS will refuse to authenticate but you can call MS and do it over the phone.
My build so far.
Total: $1475.82
Nice build. Rather than the XR look at the Supernova G2/P2 they are newer and much better. P2 got an amazing score at Jonnyguru.
Intel Inside. Overweight guy in his 30's outside.
Why do you hate windows 8.1?
Its great...
The EVGA 220-PS-1000-XR is an additional $70 and 1000 Watts may be overkill.
OP probably hates the Start Menu.
But you can intall start8 or StartIsBack plus and you can have windows 7 start menu again
Here is a pic of StartIsBack plus in windows 8.1
Edited by mosin40
Beyond the Start menu, treating everything as an app is counterproductive to me. Also, a touchscreen interface has no redeeming value for me at all.Tiles are just an idiotic way of displaying anything. I want functionality, I'm not 3, slapping and rubbing a screen will not keep me quiet and entertained for hours.
i can understand where your coming from when windows 8, i too was just searching for windows 7 to buy instead of that when it just came out but honestly, even without the installment of a win7 start menu, with the update of windows 8.1, it satisfied me enough to where I didnt feel the urge to have windows 7 as a better solution to productivity. I dont feel hindered anymore so im going to say to this is try it out and get use to it before u cast judgement cuz what you're saying no longer applies practically. it just takes one initial patience to set it all up. that's the only difference
System: Intel Core i3 3240 @ 3.4GHz, EVGA GTX 960 SSC 2GB ACX 2.0, 8GB 1600MHz DDR3 Kingston HyperX RAM, ASRock B75M-DGS R2.0 Motherboard, Corsair CX430 W Power Supply
I could make budget with Win8.1, but I just can't do it, any last suggestions, or is this a good buy?
The build:
Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($69.98 Outlet PC)
Power supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply (164.99 with $20 mail-in rebate NCIX US)
OS: Windows 7 Ulltimate OEM http://www.amazon.com/Windows-Ultimate-System-Builder-Packaging/dp/B00H09C0U2/ref=sr_1_1?ie=UTF8&qid=1414725507&sr=8-1&keywords=windows+7+ultimate ($173.99 Amazon)
Total: $1788.77
