Need urgent help for my h80i
Solved by naota3k,
I found this thread and it seemed to help. I luckily had a few plastic/rubber washers around that I put on the backplate. It was a huge pain since in the HAF 932 case the mobo cutout is really small, so I had to remove the entire mobo again.
Anyway, the problem seems to be fixed after tightening up the backplate. I put some washers like I said under it, and now I'm idling at 30C, and the highest recorded temp from Burn Test was 61 C. Hooray!
