I want to start water cooling
Look i would want a triple 120mm on the top a single 140 on the rear and a double 140 on the front
Kits are usually a good starting point, you can also upgrade them or copy the components and get them separately.
This kit from XSPC has a tube res, a good 360 rad, a D5 vario pump and the CPU block.
Add a GPU block, http://www.frozencpu.com/products/22128/ex-blc-1579/EK_GeForce_780_GTX_Ti_VGA_Liquid_Cooling_Block_-_Acetal_EK-FC780_GTX_Ti_-_Acetal.html
Can add a Dual 140mm on the front http://www.frozencpu.com/products/16829/ex-rad-430/Alphacool_NexXxoS_XT45_Full_Copper_Dual_140mm_Radiator.html?tl=g30c95s930
Get similar fittings for both rad and GPU block.
I don't really recommend the 140mm at the back, it doesn't have as much clearance, it's a pain to install with the 360 on the top, and will make little difference, your radiator surface area is even overkill for SLI.
