$1000 Rig Planning, Suggestions, Help, and Advice
Thanks for the reply. I learned mostly from other people on other forums that seem to like AMD over intel for whatever reason. Lol. I would like to know how to set up Windows to automatically send large files to the HDD. I did not know it was possible to do that. Here is the new build made with suggestions from you guys.
CPU Intel Core i5-4670K 3.4GHz Quad-Core $232.97 Motherboard Gigabyte GA-Z97-HD3 ATX LGA1150 $93.99 Memory Team Vulcan 8GB (2 x 4GB) DDR3-1600 $68.99 Storage Kingston SSDNow V300 Series 240GB 2.5" SSD $94.99 Western Digital Caviar Blue 1TB 3.5" 7200RPM $54.98 Video Card XFX Radeon R9 280 3GB Double Dissipation $199.99 Case Corsair Graphite Series 230T Orange ATX Mid Tower $59.99 Power Supply XFX 650W ATX12V / EPS12V $49.99 Operating System Microsoft Windows 8.1 (OEM) (64-bit)
$89.98
Total: $945.87
I aped for the larger SSD because I thought it would be easier to manage with the larger space, but if I could learn how to automatically redirect files I would jump down to the 120GB SSD.
http://windows.microsoft.com/en-ca/windows/redirect-folder-new-location#1TC=windows-7 for Windows 7.
http://www.tomshardware.com/faq/id-2024314/windows-redirecting-folders-drives.html for Windows 8.
The build looks good. Although I don't see a cpu cooler. If you plan to take advantage of the Z97 motherboard and unlocked (K) processor something like the Hyper 212 EVO would be a good idea.
