Need Help Fixing Matrix Platinum 290x Artifacts
Osirez
Yea, that's the plan SlaughterSmurf.  You don't think I could get anymore off of Ebay then $300?
You can try.... I mean it is a non-functioning card so who knows. I was just pulling a number out of thin air.
post on Craglist too or any other auction sites
Lesson of the week:
Asus AMD cards still suck
ARTIFACTS, ARTIFACTS everywhere
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
What PSU do you have
i7 4770k/Maximus VII Hero/Titan X/ 500gb 850evox2 r0/1000 EVGA G2
well your PSU is fine to power the 290X
i think you just got a shitty Asus AMD Card which they have yet to solve the overheating VRAM and VRMs
sell it and get other 290X or 290 like the Tri-X or Vapor-X
Well then why doesn't this issue show up on their Nvidia cards?
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
the DCU II cooler was meant for the Geforce card which runs cooler
for the AMD cards they just reused the DCU II cooler design and the VRMs and VRMs are exposed with no contact with the heat sink
I open up the 280X which has the same problem to find only the GPU is the only thing that the cooler is touching
I can confirm that this cooler was never made for AMD cards. From the research I've done its actually a Nvidia cooler retro fitted to the AMD GPUs.  And he's right.  None of the chips are touching the cooler like they do on Nvidia cards.
AH thank you for that info, I actually never new that.
|King Of The Lost|
Whats normal memory temperature.  During a run of Unigine Valley my card is showing 71c.
I think I may be onto something.  I upped the voltage on the GPU from 1250mV to 1400mV.  The artifacts did not completely disappear but they're is definatley much much less artifacts.  Almost unoticable in the Valley benchmark.  Going to do more testing and see what happens.
Any advice would be much appreciated since I usually don't deal to much with changing voltages.
I had a similar issue but my card would stop working on stock voltage. If I ran it with a voltage bump it worked flawlessly even at 1300/1600 @ 1.33v I would suggest you RMA. If it is not running properly at stock voltage it will only continue to get worse imo
You can't be serious.  Hyperthreading is a market joke?
not when they are charging him like a few hundreds for RMA
More like a deposit but ya.
To OP:
Only other option is to raise as much hell as you can with Asus. Start firing emails to head office and leaving bad reviews on Newegg and such. If you yell loud enough they will pay attention eventually.
Video demo of what happens when I bump up the voltages to 1410mV
Post the video on their Twitter and facebook pages to bring it to their attention?
|King Of The Lost|
Most definitely.  Ive been bugging the hell out of their Twitter account already, lol.
looks stable with higher voltage why is this? :/
what the hell?! Asus
Because the card is starting to fail and it requires more voltage to run properly.
Only if that was true he had the card 1 day and was artifacting, so the card is not failing. its bad VRAM
|King Of The Lost|
So under clocking mem doesnt fix it but raising the voltage does? He is getting artifacting under normal load and its not overheating so its VRAM.........
The artifact is due to poor DirectCU II cooling design having several VRAM exposed without anything in it.
Sending the card back to Asus for RMA will NOT fix the problem.
There is an aftermarket fix for it but you need to get a small VRAM heatsink to cover the exposed ones.
the process is similar to this
more info:
http://rog.asus.com/forum/showthread.php?43057-R9-280x-DirectCU-II-Top-Artifacts!!&country=&status=
Yeah, we're all just a bunch of idiots experiencing nothing more than the placebo effect.
I hate to say it but Asus Matrix cards are notorious for problems. I will say the artifacts you're showing in the video are the same artifacts I see when overclocking and not having enough core voltage applied. Just out of curiosity, what is your ASIC? You could have just got a chip that needs more voltage to operate at it's stock speeds. If that's the case, then it's RMA worthy.
5820K - ASUS X99-A - 16GB Corsair LPX - HD 7970 GHz - Qnix 1440p @ 96Hz - Waiting for Polaris/Pascal
My asics was 78% if i remember correctlly.
I dont know enough to comment on the VRAM being bad or good or anything like that.  I just know I shouldn't have to modify it for it to work stock.
U need to put heatsinks on the vram !!!!! Asus doesnt attach the heatsink to most of the vram so please dont do anything else that is your problem theres a video showing how to do it, theres s kit of vram heatsinks for under 50$ and it worx
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
