I need help and advice on my first build
I have put together a parts list for my first build but I need some more help and advice on what people think and whether anyone can see any problems.
http://uk.pcpartpicker.com/p/3CdZD
Also could we focus on the motherboard and could I get some recommendations on a good motherboard that is compatible with my parts list.
My budget is now around £850 mark.
Thank you.
Good build, I don't see any problems.
Edit: Please get a better motherboard, one with a USB 3 header.
Thanks for your reply, and the motherboard that is in my parts list has a USB 3 header doesn't it?
Oh nevermind it's on a weird location :P
So overall would you say this is a good build? and can you think of any improvements at all without a big added cost?
CPU:  AMD FX-8350 4.0GHz 8-Core Processor  (£131.48 @ Aria PC)
CPU Cooler:  Noctua NH-U9B SE2 37.9 CFM CPU Cooler  (£43.98 @ Scan.co.uk)
Motherboard:  Gigabyte GA-990XA-UD3 ATX AM3+ Motherboard  (£74.66 @ CCL Computers)
Memory:  Kingston Beast 8GB (2 x 4GB) DDR3-1600 Memory  (£53.00 @ Amazon UK)
Storage:  Sandisk  128GB 2.5" Solid State Disk  (£50.97 @ Dabs)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Video Card:  MSI GeForce GTX 770 2GB TWIN FROZR Video Card  (£239.72 @ Scan.co.uk)
Case:  Corsair 200R ATX Mid Tower Case  (£45.90 @ Amazon UK)
Optical Drive:  Samsung SH-224DB/BEBE DVD/CD Writer  (£11.98 @ Scan.co.uk)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  (£81.25 @ Amazon UK)
Total: £847.78
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-03 16:30 BST+0100)
"If violence does not work, try more violence"
Changed my parts list now with the new motherboard. Please take a look and let me know what you guys think:
http://uk.pcpartpicker.com/p/3D6Ie
Go with it.
 it's a great build but it have 2 issue:
1- get a better cpu cooler AIO liquid cooler like CM 120M or Corsair H60 (compatible with your case)
2- the case isn't well ventilated (had a single 120mm led fan at the back) try to get at least 2 120mm fans in the front (if possible with red leds) and if you want 2 others on the side (with red leds too) try CM Sickle-Flow they're great
