help with triple monitor
Cazushio
i just got a gigabyte r9 280x and i read that i dont need a active DP to get triple screen. i dont plan to game on 3 screens, i just want to get 3 screen on at the same time.
the card has 1 DVI-D, 1 HDMI, 2 min DP for output.
right now im using:
main monitor - HDMI>DVI>DP>mini DP (yes i know its stupidly long)
second minotor - DVI>DVI
tv - HDMI>HDMI
all screens at 1080p and 60fps.
cant get 3 screen on at the same time. help please
thanks
Have you set up your eyefinity group from within Catalyst Control Center?.
You will need to create a display group > Arrange your display then set a preferred display.
Just a little pointer, Download the addon called Hydravision (its on the same page you get drivers from), it makes opening programs so much easier as they wont automatically fullscreen :)
Intel I9-9900k (5Ghz) Asus ROG Maximus XI Formula | Corsair Vengeance 16GB DDR4-4133mhz | ASUS ROG Strix 2080Ti | EVGA Supernova G2 1050w 80+Gold | Samsung 950 Pro M.2 (512GB) + (1TB) | Full EK custom water loop |IN-WIN S-Frame (No. 263/500)
Check out display fusion.. i was told its good, but since i  dont have desk real estate to house 3 monitors i cannot confirm it..
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
yea, you need to set it up in catalyst
Proud Member of the Glorious PC Master Race
nope i havnt found a way to get it to work, dont really want to speed money on a active displayport, but looks like i will have too
